HELP: Heater Fan Cuts Out After 1 Min. 30 Seconds
Postby rjwoodcock » Tue Jun 21, 2016 7:42 pm
Can anyone help me with this ?? Im going to Spain and my dog will cook unless I get this sorted. The heater fan when put on full lasts for 1 min. 30 secs. and then slowly stops.....it slows to a barely perceivable speed. If I then turn it off for a few mins. I can put it on again with the same result ! Any ideas ???
Thanks,
Richard
rjwoodcock
Re: HELP: Heater Fan Cuts Out After 1 Min. 30 Seconds
Postby andz327 » Tue Jun 21, 2016 8:07 pm
Do you have a pollen filter?? Uts possible its choked
andz327
Postby rjwoodcock » Tue Jun 21, 2016 8:36 pm
I have no idea - I didn't even know they could have them ! Where would I find it ??
Thanks a million,
Richard
rjwoodcock
Postby knobby1 » Tue Jun 21, 2016 9:15 pm
What model van have you got?? Pollen filter usually lives under bonnet and in the big black plastic cabin air inlet housing .
Postby andz327 » Tue Jun 21, 2016 10:19 pm
What year and model?
andz327
Postby rjwoodcock » Wed Jun 22, 2016 8:20 am
its 2006 / 280 100hp MWB MH top, so I guess thats a mark 6
Thanks,
Richard
rjwoodcock
Postby Altransit » Wed Jun 22, 2016 3:45 pm
If it's a late Mk6, there is no pollen filter :)
The Mk7 if fitted, is in the black housing at the back of the engine bay 8)
I would guess that the fan motor is seizing up when hot :(
Postby inasinman » Wed Jun 22, 2016 3:54 pm
Sounds like a faulty heater resistor. Do a search on here or google it. It's a common problem on these van.
MK6 125/350 LWB 2.4 RWD
inasinman
Postby rjwoodcock » Wed Jun 22, 2016 7:03 pm
OK thanks for that info. I was just tinkering with it again: with engine running and fan on highest setting it cuts out at 1min. 30 secs. With engine off and fan on setting below highest it works just fine !!! Does this mean its the resistor ??
Thanks again Richard
rjwoodcock
Postby Altransit » Wed Jun 22, 2016 7:20 pm
The resistor is not even in circuit on the max setting, and if it was faulty, nothing would work on the lower settings at all.
My money is still on the fan motor itself :mrgreen:
Postby ake » Thu Jun 23, 2016 6:34 am
Altransit wrote:The resistor is not even in circuit on the max setting, and if it was faulty, nothing would work on the lower settings at all.
I agree fan motor is dying
Postby andz327 » Thu Jun 23, 2016 10:38 am
Fan motor by sounds of it, any resistor problems I've ever came across is lower speeds just dont work, I take it you've checked that there's nothing blocking the intake, maybe a rag or something while you've been working under the bonnet, definitely sounds like motor over heating and starting seize
andz327
