Arthurfron01 wrote:Ake,
Thanks for reply,
I had to take engine out a second time
because I had damaged crank sensor clamp
So put new clamp in to suit new sensor.
You say it would not run with bad sensor
But it does run (albeit with easy start under throttle and would keep running as long as needed)
Yes, but because it won't start on its own, or idle, I don't think crank sensor is working correctly, probably because it's too far from flywheel
