Running an 03 plate on vegetable oil
Re: Running an 03 plate on vegetable oil
Postby dieselhead123 » Sun Jul 31, 2016 8:56 pm
mjsroofing wrote:Cooking oil isn't good for any diesel engine because it's too think.
What do you think Mr Diesel run his first engines on then? I doubt he went down the Shell garage and purchased five liters of 'Ultimate' :wink:
mjsroofing wrote:I ran my old escort van on 50/50 oil and diesel and it blew the pump in the end. Didn't like starting in the cold either.
As Tom Cobbles says, the advise on Direct Injection engines is to 'twin tank', using a heat exchanger to pre-heat the veg oil.
The Ford Escort, unlike the Mk6 Transit, had an Indirect Diesel Injection engine, (less suited to running on veg), with no 'lift pump' to overcome the delivery problems associated with more viscous fuel.
Provided fuel quality and viscosity are well enough controlled most common rail diesels can be converted to run on 'alternative fuels', Bosch provide suitable seals and calibration data for this.
Unfortunately for those of you with 'factory' Tdci Mk6's, Ford chose to install the less durable Delphi system. Probably best to keep this on pure DERV.
Postby bambi mk 1 » Sun Jul 31, 2016 9:59 pm
Yes Tim ,Rudolf wasn't just a red nosed reindeer :wink: :lol:
bambi mk 1
Postby Jim Archer » Sun Jul 31, 2016 10:36 pm
Herr Diesel originally used 'lamp oil' - basically raw parafin. He used Veg oil - probably Castor based, same as steam plant used - as lube.
It was later that he developed 'diesel' oil as we know it today - 'parafin' is a bit too volatile and can detonate in the proper sense of the word. His aim was a power plant fuel that was safe to carry and use - unlike coal gas injection, and 'petroleum spirit' used in surface vaporiser carbs of the time which had a nasty habit of becoming external combustion engines without much provocation.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Tom Cobbles » Sun Jul 31, 2016 11:12 pm
mjsroofing wrote:I thought the 125ps tdci come out around 2005.
Any way.
dieselhead123 wrote:As Tom Cobbles says, the advise on Direct Injection engines is to 'twin tank', using a heat exchanger to pre-heat the veg oil.
So are we all saying now that if the viscosity is that of diesel then the injector pump will take it
Hence if we heat the oil up by the method of twin tank then the viscosity will be simular to diesel
Tobylex wrote: it will run for a short while then kill all the electrics on the pump
Still do not see why it would kill the electronics
Tom Cobbles
Postby Tom Cobbles » Sun Jul 31, 2016 11:16 pm
dieselhead123 wrote:Unfortunately for those of you with 'factory' Tdci Mk6's, Ford chose to install the less durable Delphi system. Probably best to keep this on pure DERV.
How do I find out which kind of engine I have?
Tom Cobbles
Postby ned » Mon Aug 01, 2016 12:11 am
75, 85, 90, 100, 115, 120 Ps 2.0L : Tddi
125ps 2.0L : Tdci
All 2.4L : Tddi,with the exception of the 135ps which is tdci but came later
Or pop the bonnet if there are wires to the injectors its a tdci if there are no wires to the injectors then its a tddi. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Tom Cobbles » Mon Aug 01, 2016 10:23 pm
nedforceone wrote:Or pop the bonnet if there are wires to the injectors its a tdci if there are no wires to the injectors then its a tddi. N
That is what I first thought originally but just wanted some kind of conformation
So it now looks like if the viscosity is correct then the injector pump will take it
Before going down the route of investing in a twin tank system, I am toying with the idea of thinking the oil out to normal diesel thickness using petrol say at 20-25% petrol to 75%-80% oil
What do you think about a petrol blend with this kind of injector pump?
I know petrol can eat and dissolve a lot of plastics and rubbers that diesel can not
Tom Cobbles
Postby Jim Archer » Mon Aug 01, 2016 10:40 pm
Petrol will affect the Veg oil. Mix up a small amount in a glass jar and leave if for a few days to see if it clouds up or separates out.
Jim
Jim Archer
Postby knobby1 » Mon Aug 01, 2016 11:34 pm
Jim Archer wrote:Petrol will affect the Veg oil. Mix up a small amount in a glass jar and leave if for a few days to see if it clouds up or separates out.
Jim
Yeah...Jim's right, the specific gravity of the oil vs petrol may be different enough to cause issues...it may well separate in the tank if left for a few days, the oil may possibly be a bit "lighter" than the oil and you'll then be running on straight petrol as it will be picked up by the pump first, not a good look for a diesel. Probably best not to run a large % of petrol in it.
As Jim says, mix some up in a jar first and see what happens..if it stays mixed and no obvious clumping or separation, you might be good to go.
Postby Tom Cobbles » Tue Aug 02, 2016 12:01 am
edited
Tom Cobbles
Postby ned » Tue Aug 02, 2016 6:18 am
I don't get it.
It seems a lot of time and effort trying different mixes of fuel/oil to get the correct viscosity.
What are you gaining by running on veg oil, what's the financial difference and mpg difference.
I am not being funny or having a dig at anybody just trying to understand it a bit more.. N
ned
Postby birdie » Sun Nov 19, 2017 12:14 pm
Before the transit, I had a Mitsubishi l200, ran it on veg and had no issues in 45000miles, the cost at the time was typically 45-55p a litre cheaper, with the correct twin tank setup it drove a bit smoother and nicer on veg, mpg was the same and it saved a lot of money, these transits however are not worth the risk in my opinion
mk7 T350 FWD towing van
birdie
Postby karl » Sun Nov 19, 2017 1:24 pm
ned wrote:I don't get it.
mix it with what :roll:
just filter it nd put it in the tank even hydraulic oil works :wink: even old engine oil but that does need work to make clean enough so you can use it :lol:
karl
Tranny Lover!!!
Postby JacobsMess » Sat May 11, 2019 11:10 pm
Did you ever try this out? Sorry to resurrect an old thread, I'm running my 2004 TDDI on Biodiesel atm but would like to try WVO sometime.
JacobsMess
Postby Mad Husky » Mon May 13, 2019 7:28 am
I run mine on long runs with half and half and it's fine anymore veg in and it runs but power seems lower, but i have a power problem anyway. 06 2.4 rwd
Mad Husky
Users browsing this forum: Google [Bot], Majestic-12 [Bot], md89
