birdie wrote:Not a good idea on anything tdci
Tobylex wrote: it will run for a short while then kill all the electrics on the pump. if you go mtdi conversion then i do believe you could then run on veg oil.
Tom Cobbles wrote:I dont know what engine it is and dont know what TDCI and TDDI isTobylex wrote: it will run for a short while then kill all the electrics on the pump. if you go mtdi conversion then i do believe you could then run on veg oil.
Why the electronics? and what is a MTDI?
Tobylex wrote:Pretty sure its been covered on here before but no it won't. it will run for a short while then kill all the electrics on the pump. if you go mtdi conversion then i do believe you could then run on veg oil.
knobby1 wrote:birdie wrote:Not a good idea on anything tdci
If it's an '03 model...it'll more than likely be a TDDi.
nedforceone wrote:mjsroofing wrote:I thought the 125ps tdci come out around 2005
My vans a 125t280 tdci on a 03 plate so I googled it and found the above info N
