ronnie.gibson.71 wrote:Thanks mechanic is coming tommorow with a snap on computer to check it properly the egr has been completely blanked off with a blanking plate I'm told mechanic mentioned injectors too are these coded for these vans?
ake wrote:So to clarify, unblock the egr, and that'll deal with the air code,
Get the prv and scv checked/ replaced and calibrated on ids, but be prepared that it might need injectors as well
Check/ replace clutch switch
ronnie.gibson.71 wrote:Cheers anyone know where I can buy good quality Prv and scv valves from?
Sent from my F3211 using Tapatalk
