Ignition key is disconnecting powers once a while
Postby pp5858 » Mon Aug 29, 2016 6:21 am
I have an issue on my MK7 that ignition key seems to move a bit up and down and it may disconnect electricity while even driving.
So If I fit key nicely and gently turn it might work well, but usually it takes few tries to get car started so that the electricity is on and it will actually run.
Does anyone have ideas what is the problem or how I could investigate what needs to be changed.
I have IDS and VCM 2 so if some change is easy and cheap to get rid of it, I could do that.
pp5858
Re: Ignition key is disconnecting powers once a while
Postby smokeytransit » Mon Aug 29, 2016 7:18 am
Ignition switch is a common problem on these.
Ford, all the power beyond the world.
Mk6 transit 85 t260
smokeytransit
Postby Dodge20 » Mon Aug 29, 2016 9:56 am
smokeytransit wrote:Ignition switch is a common problem on these.
+1. Also it's not difficult to replace or expensive.
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby pp5858 » Mon Aug 29, 2016 1:00 pm
Tnx for info.
Is there thread for changing it how would it happen or quick list/order what to do?
Do I purchase it as new or is second hand also possible and can I keep the same key mechanics / keys?
pp5858
Postby Altransit » Mon Aug 29, 2016 3:56 pm
Yes it is a DIY job, no new barrel or key required, just remove and change the switch on the back :D
Postby karl » Mon Aug 29, 2016 3:57 pm
as above :D
karl
Tranny Lover!!!
Postby pp5858 » Mon Aug 29, 2016 7:44 pm
Sounds great, would someone have the spare part number in hand or picture of it.
pp5858
Postby ake » Mon Aug 29, 2016 7:49 pm
Postby pp5858 » Tue Jan 17, 2017 10:46 am
btw. Switched this part, easy change and corrected the issues as expected.
Though now (half a year after I changed that or so) have issues that there is some miss alingment or so on the key. Not exactly sure but when I got my car back from my wife, she complained some beeping issues with the car and lights on the dashboard even after the key has been taken out.
When I got to car to try to start it, there were some lights light on the dashboard and could not turn the key so that it would start. After a while I got it started but when I turned it of there was horn or something loud noice.
And after a while it went even worse, I could not shut down the engine, but instead the key turned off, car was running and the horn noise was there.
In the end I had to take the battery - cables out, put it in a gear and stall the engine to stop it.
Still haven't had time too look what is really wrong with the car.
pp5858
Postby Altransit » Tue Jan 17, 2017 10:56 am
It sounds like the new switch has failed :?
Postby loot » Tue Jan 17, 2017 2:07 pm
+1
Also make sure the key and barrel aren't over worn/sloppy, i bet that won't help the switch especially if there's lots of keys on the keyring weighing it down.
Ids map here
loot
Postby pp5858 » Wed Jan 18, 2017 2:36 pm
Hmm, quite didn't yet figure out what was the issue but managed to get it fixed.
Probably it is the switch some how but now it works fully. Have to look more detailed during the weekend and see it more detailed if I could figure out why it did that.
pp5858
Postby rimotu66 » Wed Jan 18, 2017 2:54 pm
:?: :?: so what did you do to 'fix' it?
2007 SWB 110PS GLX Mk7
rimotu66
Postby pp5858 » Tue Apr 25, 2017 11:42 am
I'll still reply to this even months old. So I didn't know exactly then how or what I fixed and even now dont know. :o
So It was some how misaligned and I think I just turned it back and forth or so and once it got aligned it has stayed there. Plus, I've been the only one driving it since. ;) Not blaiming anyone but....
pp5858
