Have you checked to see if there is power to the light unit
Power to the load space lights is controlled by the rear cab light switch, so if it's off, the load space lights will be off too. If the cab light doesn't work either, then you may have a blown fuse.
If you do have power at the rear light, you may have the LED's connected the wrong way round
