Altransit wrote:Just out of interest, do you have a cost breakdown for the various parts
Good step by step with piccies, do you mind if I put a copy in "technical how to"
Mike wrote:I'll be interested to hear how you think they perform.
Altransit wrote:t2myd wrote:Altransit wrote: Had mine on most of the day due to the "interesting" weather we've been having
I didn't need them, but it was cool to have them on, even if there's no useful light
So you got them working , did you put electric window in the van
Yep, all fitted and working OK thanks buddy
Jaydog wrote: Sorry to butt in on this thread but when you added electric Windows how did you manage to unplug the connector between the door and body as I'm having a nightmare. Ta!
Altransit wrote:Jaydog wrote: Sorry to butt in on this thread but when you added electric Windows how did you manage to unplug the connector between the door and body as I'm having a nightmare. Ta!
I just used my index and second fingers either side, and wiggled it carefully, and my fingers aren't small
loot wrote:If you have the correct spec loom then there will be 2 dog light connectors near where they sit in the bumper by the inner wings.
If you do not have the correct loom then there will be nothing anywhere. It has been a long time since I added mine but I know I had nothing.
I can search later but you only need to feed 1 cable through to the bcm and get the fog light switch and maybe get fogs activated in configuration to fit the lights. The wire can feed both fogs in and then negative ground them at the 8mm chassis leg ground bolt point.
I recall that I looked a small hole through the bulkhead grommet and fed the cable through.
Most ppl hear bcm and swerve it though so let me know if you want the pin number.
loot wrote:Front fog supply f80 is 15A and the bcm is located remove the glovebox, look for the main fusebox and above it are 2 tabs to splay outwards, this allows it to flip down and reveal the bcm and its fuses.
You need connector C2 pin 19 (it should be empty) you need to get a lie connector and wire and insert it into that spot.
That then goes to both front fog lamps, through to chassis ground. It isn't that hard to do but if you aren't that easy inclined then you'll need to find an auto electrician.
