Punto443 wrote:I don't think I've ever heard of a mk6 pump failing mechanically ever?
I've had a few in
Ford released a TSB for it.
8/31/05 Engine undershooting to a stop, lack of power resulting in reduced top speed, hesitation or failure to start 42/2005 Should a customer express concern about the engine undershooting to a stop, lack of power resulting in reduced top speed or failure to start, one of the the probable causes is cam plate failure in the Bosch VP30 fuel injection pump, caused by contamination of the fuel system. To rectify this concern, a new fuel injection pump, fuel injectors and high pressure fuel supply lines should be installed, the fuel system thoroughly cleaned and a fuel additive should be used.
Failures will occur due to: Water in fuel. The capacity of the water trap in the fuel filter is around 100ml. Should a poor fuel quality supply be used or service intervals missed, the water trap will become inadequate. The water in the fuel will cause corrosion inside the fuel injection pump and lack of lubrication, which will lead to damage of the highly loaded cam plate and cam plate rollers. Petrol in the fuel. The cam plate and cam plate rollers being the highest loaded components in the fuel system need good lubrication, hence if petrol is in the fuel, wear of all components needing lubrication will occur. Failure of the cam plate can also lead to failure of the fuel injection pump front seal. This will allow diesel fuel to enter the sump and potentially cause catastrophic engine damage.
If the regular service intervals have not been maintained, use of a poor quality fuel supply (such as a customers own fuel storage system), or petrol in the fuel suspected, the warranty claim must be rejected. This bulletin does not remove the necessity for prior approval when installing a new fuel injection pump (where necessary). Diagnostic Trouble Codes (DTC's) are not always generated by this concern except in some instances where there is also a pump timing code. When installing a new fuel injection pump, the old pump must be returned in accordance with TSB 98/2004.
Listed here with the rest
viewtopic.php?f=31&t=154710#p1304317
