by ray1965 » Sun Sep 25, 2016 8:43 pm
the e-bay kit is a good one, i have fitted it to both mine and a friends, even if you dont think yours is worn, you wont believe the difference once you have it in your hands
the thing that doesnt come in the kit is the bush that sits on the ball at the bottom of the stick, but thats £5 from the dealer (the figers break off on them as well as wear)
you have to take the bolt bushes out of your old one and fit them in the new one, and mark the old one where it sits and the bolts sit, as its adjustable, your supposed to use a ford tool to lign it up, but you dont need it, just mark it, although i have found just push it to one side and all is ok, if you get it too far one way you will loose reverse and 5th gears
when taking it apart and re assembling, bear in mind its a sprung assy, the grease will have dried out in the old one, use pleanty of grease on re assembly
as said, pinch bolts both work loose and my one had snapped, even if it looks ok, take it out and replace it, the shaft of the bolt severely wears, and eventually snaps, i replaced mine with a std bolt and lockwasher
you cant but the e-bay kit from Fords, they quoted me about £150 for a complete new lower stick assy
