Hattons wrote:Hey guys, i've decided to create my own thread.
Right now i'm looking for parts to do service. Anyone know OEM part numbers of air / fuel / oil filters? Also i'm going to use Castrol W5-30 EDGE fully synthetic oil. How do you think this is correct choise?
2011 reg MK7 Transit 2.2TDCI 85PS
Many Thanks!
amlav wrote:You most likely need to replace glow plugs too . Don't replace only the fusiable link (wire). After all one ore more of glow plugs are shorted .
The internal carbon layer beetwen central rod and outside shell in time is burning away and do to vibration it will short out the glow plug .
Hattons wrote:Can anyone forward me where I can buy obd reader. I'm not sure which one gonna work with my van. Up to 100 quid. I want to make sure check engine light stays because of glow plugs. If so I'll change all glow plugs with fuse. Thank you guys for help
Hattons wrote:BTW EML light disappear if problem is fixed or it is stored somewhere and you have to clear fault codes anyway? Thanks!
Punto443 wrote:Get the engine red hot before attempting to remove the plugs.
Users browsing this forum: Baffles1982, Bing [Bot], Google Adsense [Bot]
