Now I have searched this honestly guvnor, but do I need any special allcock tools to change this stupid part.
Looking at the new one I assume it presses in from the bottom of the hub and is secured with the circlip provided, I was hoping this part wouldn't fail on the mot but it bloody did.
Am I best removing the wheel hub and going to the garage to see if I can use there press.
Many thanks N
Having never done this job on a transit I may be wrong but having replaced many ball joints on many other vehicles I'd say a press would be a good idea.
In order to get it on a press, you would have to remove the whole hub carrier and calipers etc.
I've always found smacking it out with a hammer and chisel, then bolting it all up and jacking the bottom of the wish bone up to insert it has worked for me.
I can vouch for that I used a inner track rod to repair my fire grate BOOOOOOOOOOOMMMMMM shake the room red hot coal and several small fires in the drawing room /refectory don't do it b b b b b baby
Not started yet not long since I got up here's my plan,
Take kids to school Have a coffee and a fag Make a start on the van using the 3 girls sally sledg, Lisa lump hammer and Tracy trolley jack Swear, shout, smoke, shout, smoke, swear, drink, girls, feck, arse, smoke,
Sound a good plan and sh*t them ball joint go off like a rocket with heat (watched the you tube videos) N
