hi Guys
just bought an ex rac mk6 panel van, the van has a rear tailgate, as it has the quick deploy trailer fitted, the rear windscreen wiper was removed when they fitted the stripes to the window
im just having some welding done, and one of the areas is the near side inner sill, right at the front corner where the mud flap is, the hole was about 100mm x 600mm, so you could see in it, it looked empty and the outer sill in good order
having that the hole is now plated, there is a water leak from that spot welded seam, and its not stopped after 6 hours of dripping from 3 places and putting a large puddle on the floor
washer bottle looks tike the rear wash has been blanked off at the bottle/pump
now obviously the welding has melted a pipe/hose, but does the rear washer pipe run thru the inner sill, or does something else carry water thru it
bearing in mind nothing could be seen in there prior to welding, and the water is not stagnant, or have anti freeze, its just plain water
