transit mk6 running problem
Re: transit mk6 running problem
Postby 101jyd » Sun Feb 26, 2017 5:29 am
hi can someone pleassssse help me get this piece of sh.. running as it needs pump programming to the ecu. I've bought the cardiag j2534 with the ids v101 software and the software does not open up, I've done it all according to the video but will not open all I get is the vm workstation working that's it. and now I'm getting stressed out, I've now been off the road for 5 months now ( grand and a half wasted just on insurance) without all other expenses and all its doing is just sitting on my drive, now the m o t has expired, all I need is someone who has ids to sort it out, asap so I can then get back on the road regards, al.
101jyd
Postby chris72a » Sun Feb 26, 2017 5:36 am
I feel ya frustration hopefully someone will be able to help you out shortly.. Offer a carton of beer :-)
Chris
chris72a
Postby 101jyd » Sun Feb 26, 2017 12:05 pm
I don't mind if it costs me to get it done I just need it done so I can get it moted and use it again, regards al,
101jyd
Postby 101jyd » Mon Mar 27, 2017 7:55 pm
hi all, still struggling to get this van started, fitted a replacement pump, ecu, transponder, chip, for key, from a running van, which I bought off ebay, and now I'm not getting any fuel up to the injectors, when I had original pump on I was getting fuel to the injectors any idea's how I can get this sorted, regards al.
101jyd
Postby 101jyd » Tue May 16, 2017 11:42 am
hi all, I now have replaced engine with a 125ps and done away with the 90ps and it ran well for 3 weeks, went through mot sweet, now it's problem is with excessive fuel consumption/black smoke when warm (8 miles on £20 something seriously not right) and when clutch is engaged I have revs but when disengaged the van will not rev properly with lack of power and all works fine when cold I've had it plugged in and no codes, any idea's
101jyd
Postby 101jyd » Tue May 16, 2017 2:16 pm
sorted, blanked egr valve and hey presto no smoke, power is back as it was in fact better, fuel economy much better, and it revs up fine, finally all I need to do is sort clutch thrust bearing out which only lasted 2 days and it's noizy again, after replacing a new clutch 1 week ago, what a ball ache, now I've gotta remove gearbox again,
101jyd
