ake wrote:Why?
Egr opens at part throttle and part load
It closes at full throttle and full load
knobby1 wrote:If you suspect the EGR is faulty..I'd just replace it...not worth the grief of trying to save a dead one....
rossco_pb wrote:No, do not suspect it is faulty, just would like to understand how it operates when it is supposedly working correctly;-)
knobby1 wrote:rossco_pb wrote:No, do not suspect it is faulty, just would like to understand how it operates when it is supposedly working correctly;-)
Fair enough....as ake says....the EGR is normally open at idle, as we approach part throttle/part load it incrementally closes the higher the throttle position/load....and vice-versa. With the electronically actuated machines such as the 140 RWD and a few others...the PCM senses MAF, MAP, RPM, throttle position etc...and adjusts the VNT guide vanes to suit....this is why we can have full boost at 100kmh pulling up hill at full throttle or very little to no boost at 100kmh going down a hill with no throttle....it's constantly variable and works pretty well tbh.
As I understand it...when a vehicle is "mapped" for performance, the tuner can change things around to allow for variables/changes in fuel flow and/or turbo boost to achieve the desired results, better mid range, top end or economy etc.. The map itself is 3 dimensional and changing one thing will undoubtedly affect others, if it was easy...we'd all be doing it. Actually I'd love to learn more about it myself.
It doesn't take a genius to understand a small error can cause a lot of damage, this is where guys like Martyn, (Vantuner) are invaluable to our little community.
Sorry for the rambling....and I stand corrected as usual.
v8dave wrote:This is what you want.
The wire to pin 4 is Grey and Blue, it connects to the ecu.
rossco_pb wrote:Ok, bought a digital voltmeter gauge that I am gonna stick on the EGR position wire - will let you know the results and how it ties into turbo boost (if at all) -
loot wrote:If you are trying to bypass the egr mechanically you'll have to use the pulse going to the motor, but it may not be the only hurdle along the system.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
