Hi all newbie transit owner here, 2005 mk6 I believe 2.0 durateq ex post office.
Purchased last week (Gumtree) after driving in the salty road conditions I tried to clean my windscreen but nothing, no wiper movement and no water and also no audible noise from the washer pump. After checking some fuses which I found online and were good, I then decided to check where the pump was located. After peeling back the plastic trim in the front near side wheelarch I found that the plug for the pump was just dangling there. So I put it back on, went to try it but still nothing. I left it plugged in anyway so I just started the van up and began to drive away when all of a sudden the water started to spray as it's supposed to from the washer jets, but it wouldn't stop, kept going until I removed the plug from the pump. Is the pump goosed or something more sinister like wiring problems etc.
Any suggestions would be appreciated.
