Retired John wrote:good when key is in start position so fault appears to be between key and main fuse box , tomorrow I will attempt to dismantle the ignition and remove the unit itself any easy ways or clues ? the only manual I have is a useless haynes one best used as a doorstop
The ignition switch just clips on the back of the key barrel, 10 minute job...
