Altransit wrote:The relay itself may be fried Once the fusible link is cut it shouldn't be passing any current. Check the relay bases in the fuse box for heat damage
That's what I said...I think..!
knobby1 wrote: That's what I said...I think..!
Altransit wrote:Yes, but you have the advantage that your posts will always appear before mine, since you are further East ........................... it's either that or I just never looked at your post before posting mine
I could just delete your post, and make me look like the clever one
nedforceone wrote:I have no glow plugs running in my van due to the 'it will end in tears' (1 snapped in the head) so I believe lots of wd40 or your equivalent and getting the engine warmed up before starting the job helps. N
Retired John wrote:nedforceone wrote:I have no glow plugs running in my van due to the 'it will end in tears' (1 snapped in the head) so I believe lots of wd40 or your equivalent and getting the engine warmed up before starting the job helps. N
Thanks for the tip have heard this
2 questions how hard is it to start when cold ? coldest we are likely to experience is 0-3deg
Why not do as a mate tells me he did he had 2 that would not budge so isolated then so they were off grid so to speak and the other 2 still work which seems to make him happy ?
nedforceone wrote:That's an expensive can of start ya barsteward Think I paid £80 for 4 glow plugs what's that about 120 aus, so what you've been charged is quite reasonable considering the price for some parts in your sunnier climate. N
Retired John wrote:nedforceone wrote:That's an expensive can of start ya barsteward Think I paid £80 for 4 glow plugs what's that about 120 aus, so what you've been charged is quite reasonable considering the price for some parts in your sunnier climate. N
Glow plugs were KLG and $26 each the inlet gaskets $5 each so $40 I was quoted more for 1 at Ford than 8 at Mick Miles http://www.fordtransitparts.com.au/
nedforceone wrote:Retired John wrote:nedforceone wrote:That's an expensive can of start ya barsteward Think I paid £80 for 4 glow plugs what's that about 120 aus, so what you've been charged is quite reasonable considering the price for some parts in your sunnier climate. N
I have to get the inlet gaskets for mine along with everything else on the to do list, timing chain kit, service kit, brakes, wheel bearing, injectors, fuel pump the list goes on, it would be cheaper to buy a new van but I love my van even though it is a tdci and wants to kill me N
@n you should be making money
