Stream wrote:Is it also possible to set the idle higher with the ids software? The idle is now around the 800rpm, but according to the data sheets it's had to be +/-850 rpm?
knobby1 wrote:Stream wrote:Is it also possible to set the idle higher with the ids software? The idle is now around the 800rpm, but according to the data sheets it's had to be +/-850 rpm?
No, idle is not user adjustable via IDS..! It's preset in the PCM firmware. It may be adjustable via a remap but I'm not too sure about that.
Normal idle is ~800rpm +/-50rpm...and when A/C is turned on the idle should rise to ~900rpm.
The Anti-Stall function, (if enabled via PCM update), will also increase the rpm when pulling away from a stop.
Stream wrote:tried again to do the pump learn this morning but it's almost complete and then it's fail again because: code 01 idle rpm is out off range.
Does someone know it's fails because off a faulty scv?
