nedforceone wrote:
I would be checking all water hoses especially around or above the exhaust as one could be leaking and dripping on the exhaust causing the smell, have you removed each hose to check there not gunked up inside.
George106 wrote:Been to Autobarn today and got new Head gasket repair product recommended ( https://www.nulon.com.au/products/Cooli ... ket_Repair ) which is gonna hopefully sort the problem out. I got a lot of pressure in the system and layer of small bubbles in header tank so it needs to get the air from somewhere.... Also noticed oil leak around vacuum / water pump... so may have to change gaskets.
George
