Help with PAS needed please.
Re: Help with PAS needed please.
Postby fitzy » Mon Oct 16, 2017 12:10 am
Thank you Knobby.
Do you know if the solid pipes on the actual steering rack from the pinion to rack have O rings? Found the pipes on eBay and ford parts catalogue but electronics parts catalogue doesn’t show any O rings for these pipes, only the 2 pipes part numbers?
Dave
2002, 52 Reg, 125-T350, LWB, Semi High Roof, Metalic Pepper Red.
Electric windows, Electric heated mirrors, Cental locking & Air Con. In the process of retro fitting Heated Screen & Fog Lights.
fitzy
Postby knobby1 » Mon Oct 16, 2017 3:42 am
fitzy wrote:Thank you Knobby.
Dave
Yep...as per the parts catalogue drawing in my previous post...Pn's: 4727791 & 4727793
Postby fitzy » Mon Oct 16, 2017 1:32 pm
Those O rings are for the feed and return pipes from the pump and reservoir which I need as well, I was asking about the 2 solid rack pipes that are on the actual rack itself.
Dave
fitzy
Postby knobby1 » Mon Oct 16, 2017 7:37 pm
fitzy wrote:
Dave
Ahh...Sorry, my apologies. :oops: .. I thought you meant the ones I mentioned as they're the only one's available from Ford.
The two high pressure "transfer" lines on the rack itself are actually part of the rack and not supposed to be removed....but I'm sure someone has possibly done them before...might pay to do a bit of googling/bootoob etc....! I've not had them out of mine.
Postby fitzy » Mon Oct 16, 2017 8:47 pm
fitzy
Postby knobby1 » Mon Oct 16, 2017 8:51 pm
Quite right you are Fitzy...I'll keep my gob shut now..! :oops: :wink: :mrgreen:
Postby v8dave » Mon Oct 16, 2017 8:54 pm
Since the parts diagram shows the pipes but no seals I suggest that there are no seals fitted to the pipes.
The are probably a soft metal with a flared end like a brake pipe.
v8dave
Postby fitzy » Tue Oct 17, 2017 8:56 am
v8dave wrote:Since the parts diagram shows the pipes but no seals I suggest that there are no seals fitted to the pipes.
That’s what I thought having looked at the pictures of actual pipes on eBay. Flared ends just like brake pipes. Just wanted to confirm my findings.
Dave
fitzy
knobby1 wrote:Quite right you are Fitzy...I'll keep my gob shut now..! :oops: :wink: :mrgreen:
You’ve been a great help Lord Knobrot. :D :D :D
fitzy
Postby knobby1 » Tue Oct 17, 2017 8:59 am
You're too kind..! :wink: :mrgreen:
Postby Fedupfatman » Tue Oct 17, 2017 10:38 pm
Sorry gents, only just seen the updates to this thread. The pipes that I needed to fit were on the rack itself & did not have or need any O rings. As one member suggested they were flared at each end, I just applied a little hydraulic thread lock to the nuts before assembly. I found a guy selling both the pipes needed for £23 for the pair, my local Transit dealer wanted £55.00 plus vat for each pipe! Guess which option I went for.
2004 90-T350 2.4 DI
Fedupfatman
Postby fitzy » Tue Oct 24, 2017 6:40 pm
Fedupfatman wrote:Sorry gents, only just seen the updates to this thread. The pipes that I needed to fit were on the rack itself & did not have or need any O rings. As one member suggested they were flared at each end, I just applied a little hydraulic thread lock to the nuts before assembly. I found a guy selling both the pipes needed for £23 for the pair, my local Transit dealer wanted £55.00 plus vat for each pipe! Guess which option I went for.
Did you have to remove the steering rack or is there enough room to replace these 2 rack pipes in situ?
fitzy
