Fedupfatman wrote:Upon inspection, I found the PAS fluid leaking (squirting) from one of the small diameter pipes on the steering rack.
Fedupfatman wrote:Me again chaps. Managed to get the little "bleeeeeep" out. I poured some hot water over it, then gave it a few light taps with a small drift & hammer & she slid right off. Thank you again for your help everyone. However, the pressure pipes that fit from the pump & cooler, they seem to be stuck in with no obvious way to get them free. I've undone the little bracket that goes around the base of the pipes, but the pipes are stuck fast into the PAS rack housing. I've managed to work the rack out with the pipes attached (God knows how but I got it) but I was wondering if they should come out? Are they possibly corroded in too? Thanks guys.
fitzy wrote:I know this thread is 9 months old now, but I need to replace the 2 rack pipes as one of mine has just sprung a leak. Do this 2 solid rack pipes have ‘O’ rings fitted or are they self sealing pipes?
Cheers
Dave
blue estate wrote:O rings
fitzy wrote:blue estate wrote:O rings
Are there any part numbers for these O rings? Found the pipes on eBay but not the O rings. Plus these pipes aren’t on the ford electronic parts catalogue.
