I've had my MK7 Transit for over a year now and gone from 127000 miles to 153000 miles in that time. I have serviced it myself during that time with no issues at all. Recently, I decided It was to cold to get underneath so decided to get a local chain garage to service for me. All went well except that the technician could not move the oil filter housing and said it was too tight and could'nt move it without damage and that the sump drain threads had worn and could not do up the plug tight enough. I never had any issues with these parts before and while I did'nt use a torque wrench on either, I know they were not overtightened.
Is this issue common to Transits?
I have done some research and a new filter housing is cheap enough as is a new standard sump. I have also seen a high capacity sump which holds more oil and claims to give smoother running, more mpg etc. Is this a worthwhile upgrade?
Any advice is appreciated.
It's a 2007 2.4 RWD flatbed by the way
Cheers in advance
Dave
