bobson6 wrote:EGR Valve, SRV and PRV ordered. Fingers crossed that solves it.
Once they are all fitted, Is it then you run the fuel system learn? Help with this would be appreciated as this learn process is new to me.
Thanks Craig
bobson6 wrote:Error code p1402? Any ideas? Map/Maf sensors as new egr fitted?
bobson6 wrote:Not had chance to clean the MAP sensor, but managed to get FORscan to work on my laptop and got the following
p1402 - EGR valve position sensor/wiring - Circuit voltage bellow threshold
P1402 - EGR System Fault - pending malfunction is expected to be confirmed
I fitted a new EGR Thursday and the van drives fine, I fitted one of the newer style ones with a black body from Transit Parts UK. Will this cause this problem? Do i need a PCM update? not sure if it has ever had one.
loot wrote:The new egr is fine i fitted it on my mk7 a few months ago and no problems reported.
There is the chance that the fault is with the wiring, this would make sense as you had the fault on both the old and new egr.
Or slimmer but still possible the new egr is faulty.
knobby1 wrote:loot wrote:The new egr is fine i fitted it on my mk7 a few months ago and no problems reported.
Bit slow this morning Loot..??
loot wrote:Slow? This morning? Every morning
