karl wrote:Engine,engine bay wiring loom dash wiring loom , digital clocks etc and a load of time
bambi mk 1 wrote:What year are the donor parts from
reaperkinqs wrote:bambi mk 1 wrote:What year are the donor parts from
05 plate
bambi mk 1 wrote:If both are 05 you may get away with the ecu ,115 pump and injectors.The dash and engine bay loom should be ok but the engine loom may not
reaperkinqs wrote:bambi mk 1 wrote:If both are 05 you may get away with the ecu ,115 pump and injectors.The dash and engine bay loom should be ok but the engine loom may not
oki thanks for all the help mate one more thing the ecu in the van is a 90ps and i want to use a 115 engine pump and injectors wont i have to change the ecu
Altransit wrote:reaperkinqs wrote:bambi mk 1 wrote:If both are 05 you may get away with the ecu ,115 pump and injectors.The dash and engine bay loom should be ok but the engine loom may not
Yes, ECU, Pump, and injectors all needed, plus possibly the engine loom
grandads_shed wrote:correct me if im wrong , but if the ecu is changed dont it need the keys reprograming as well ?
oki thanks for the info mate i will be doing the swap some time this week i will update and let everone no how it went
oh one more thing sorry about this but can i use 115 injectors on a 90 engine
Are you changing engine from 90ps to 115ps
or
changing engine from 115ps to 90ps
Going on you previous thread. viewtopic.php?f=5&t=175968
You have a 2005 Transit mk6 2.4 115ps.
Now you're asking if 115ps injectors will fit a 90ps engine.
Would've been far easier to say.....
Look I have a mk6 2.4 115ps. Engine is shagged. Can I use a 90ps engine with 115ps fuel pump, injectors & turbo fitted to it.
NOTE:-
90ps uses a Bosch VP30 fuel pump.
115ps uses a Bosch VP44 fuel pump.
