Gjinna wrote:Hiya guys my p8fa blew up on me but found a qvfa engine will it be ok in my 07 minibus mwb
Gjinna wrote:Great what's the problem with qvfa to p8fa I'm intrigued
Gjinna wrote:Ahh ok so basically putting a qvfa engine in the ecu will make it essentially a p8fa willl I need any other parts or is it simply plug and play
Gjinna wrote:Can't use original injectors as number 2 blew the engine and took out the turbo by overheating it so am I good using this qvfa with its own injectors and turbo
Gjinna wrote:jut to update my mechanic fitted the qvfa with p8fa turbo and got it running with a ford engineer and his equipment and yeah its running ok but when i plugged my opcom in its still got the old injectors coded in is it important i read the codes on these injectors and code them in or does the injector/pump learn do it
