Intermittent ecu light on with loss of power.
Postby Parsons1989 » Tue Mar 21, 2017 9:10 am
Hi wondering if anybody can help, I have a 2013 ford transit 2.2 diesel and intermittently the engine light comes on and it goes into limp mode.
If it turn engine off then back on it is fine, I have a Launch code reader which is very good at ford but there are no faults in the ECU,
I no EGR valves are common to play up on them so replaced the EGR valve and reset the settings of it, but it appears to of made no difference.
Any help solving this would be greatly appreciated.
Parsons1989
Re: Intermittent ecu light on with loss of power.
Postby Punto443 » Tue Mar 21, 2017 11:42 am
Better getting it on ids, for a more indepth diagnostic.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Parsons1989 » Tue Mar 21, 2017 1:01 pm
I have a launch code reader that is mostly set up for Ford and it is giving me no fault codes.
Trouble is I no of few things it could potentially be but not in the position to be throwing money at it :lol:
Parsons1989
Postby knobby1 » Tue Mar 21, 2017 7:23 pm
Parsons1989 wrote:I have a launch code reader that is mostly set up for Ford and it is giving me no fault codes.
If the light comes on at all it "WILL" have stored a fault...whether it be current, pending or historic...Your "launch" reader won't be able to see the "Historic" or "Pending" codes....She needs to go on IDS...IDS sees all.
Postby Parsons1989 » Wed Mar 22, 2017 8:52 am
Ah right ok looks like a trip to main dealer is most likely on the cards :(
Parsons1989
Postby knobby1 » Wed Mar 22, 2017 7:30 pm
Parsons1989 wrote:Ah right ok looks like a trip to main dealer is most likely on the cards :(
Not necessarily....there may be a member with IDS who can help....whereabouts are you..!??
You'll have your pants pulled down at the dealer
Postby Parsons1989 » Thu Mar 23, 2017 10:10 am
Dreary England :lol:
Parsons1989
Postby Parsons1989 » Thu Mar 30, 2017 12:23 pm
Still not managed to get this into the stealer but thought I would provide an update,
Have carried out Stationary Regen of the DPF and the light has not come on since.
But I do have an intermittent battery light coming on now, seems occasionally the charge rate stays at 12volts at idle.
Parsons1989
