WarrenB wrote:I had a case of the mysterious missing coolant last year. No signs on obvious leaks but it'd occasionally leave a puddle of coolant underneath when parked up after a long run and the engine was warm.
Turned out there was a tiny hole in the bottom of the radiator that was impossible to see unless you were double jointed and had a head the size of a pea.
Also worth checking the pressure cap on the coolant bottle. Only about a tenner direct from Ford so a good place to start if there's no obvious leaks.
Andrew1974 wrote:Update.
I've found the leak, it's at the back of the coolant pump. It's leaking slowly, I'll take a picture later. It looks like there's a seal that it's leaking through. It's at the section right at the back of the pump, three hoses meet and connect to a black part that connects to the pump, it's leaking where that section meets. Will the whole pump need replacing and how big a job is that? Or is there rubber gasket that fits inbetween or is it one sealed unit? What sort of cost will a new pump be ? Thanks for the help.
vampirequeen wrote:Put your registration number into the Europarts website and search for antifreeze. It will show you the ones it sells that are suitable for your vehicle. Then you'll see whether it's pink or blue.
