rustytransit wrote:Knackered scv valve.
If there is any hint of rough idle I will bet a new scv will cure your problem !
bambi mk 1 wrote:rustytransit wrote:Knackered scv valve.
I bet it wont 2004 wont have one
hunkey monkey wrote:its a 2.5 litre rear wheel drive 2004 model
hunkey monkey wrote:I cant see anything on the van that says what it is,it might be a 2.4 I think,on the door it says 90t350 if that helps
hunkey monkey wrote:not sure what code reader was used but ill pass what you said onto the mechanic,thanks very much
