Hi. I have a 2001 280 2.0L Duratorq DI (75PS)
It is very noisy, diesel knock. Starts fine but hunts if left on tick over till it starts to warm up a bit.
No rev counter so can't give figures but when I take off it seems to pull but has a very short and when past it is very slow to reach full revs.
When the weather is fine and dry as it gets to the end of the power band the heater plug light starts to flash and then there is a drop in power. if it is foggy or raining this does not happen but there is not much of an improvement in performance.
When the light does come on and I come to a down hill bit of road I turn the ignition off and back on and it is ok again.
I would like to get an OBD reader but the ones I have seen all seem to be for Diesels from 2004, maybe someone can point me in the right direction for something suitable.
My only experience with diesels is a 1994 2.8 TD that I had and sometimes the waste gate actuator would play up and I fitted an EGR blanking plate.
I learnt my trade at a BL garage between 1975 and 1981 and have been out of it ever since.
All help will be gratefully received.
