hi Guys
need a little help here, i think going by the threads on here, my 2 litre transit has a timing solenoid issue, theres a lot of diesel knock cold, it gets better warm but still a tad too noisy, and its burning a little more fuel than normal, the pump was taken fromm a 150k van just over a year ago, with the original pump considerably over dieseling, pumping black smoke out
so looking to get a new timing solenoid, i went to the stealers, they said theres 2 types, one used std bolts and is about £200, the other uses torx and is £700, feck i thought if its the later i can buy a new pump, so looking on flea bay, ive come up with the following, however, the first dosnt seem to have bolts, but a collar nut, the pump on the van has the collar nut on the solenoid on the end, as does the one ive just taken from a scap van, but its not described as a timing solenoid, its called a fuel metering solenoid, or are they one and the same hing
but am i looking at the right parts, pls advise
http://www.ebay.co.uk/itm/GENUINE-NEW-B ... 1977113625
http://www.ebay.co.uk/itm/GENUINE-BOSCH ... 1861100734
theres very few on flea bay, and the bolted one dosnt state bolt type, is there a different one
its a 2 litre with VP30 pump
