Gday all I need some help.
I have what I believe is a Mk6 2.4TDDI 90ps minibus
Im having some problems with performance especially at low speed, ABS and a speedo fault (probably wrong diff ratio) as per previous post.
So I bought a VXDIAG VCX NANO with IDS 101
Got that setup and plugged it in.
IDS reported the basics of the car but with 120PS engine and asked if that's right and I said no.
It then said wrong PCM calibration or similar.
So I looked at the log viewer and found this
OXAB01
Module Part Number : 1C1AND
WF0AXXGBFAYL33485
Vehicle, engine, capacity, Pats, transmission, fuel, etc all correct (I think)
Power : 120PS
Now that's not my VIN its WF0EXXGBFE1A60721 and ETIS lookup data seems to match my vehicle and says I have a 90ps engine which given the fuel pump and turbo size Id say is correct.
I think the tear tag number on the van is YC1A. (label inside passenger door, first 4 digits)
So whats up? has the PO changed the PCM at some point and it has the wrong calibration or in fact wrong PCM?
Is this fixable?
Any assistance appreciated
Thanks in advance
