by leetheedge » Fri Mar 24, 2017 4:59 pm
HI GUYS BACK AGAIN WITH YET ANOTHER PROBLEM..
when I turn left around a corner I hear an intermittent scraping/creaking noise. ( usually 3 or 4 times )it only happens when I turn left..when the van is static and I turn the wheel there is no noise. it seems to be worse when ive got my clutch in or when I freewheel it.
I phoned the garage and they said its probably the lower ball joint cover catching the disc,,im not totally convinved thou as on inspection the cover doesn't look that close to the disc..any advice would be great.
cheers
