Hi all,
Have a problem, van runs fine at low revs but when you put your foot down it lacks power intermittently in a way I can only discribe as someone pulling the handbrake on and off. Started last Sat after I put diesel in on Friday night so was thinking might be crap fuel filled up again Thursday but still the same at the minute. Had a new fuel filter on a few months ago and blanked the egr valve five weeks ago but was fine after that never deleted the egr though if either of these could cause it? Also speedo not working for last few weeks which I've been told two abs sensors are down not sure it this might have any bearing on it.Thanks van is 2006 2.2 110 Swb mk7
