G'day gents,
Apologies if this has been covered in another thread on here.
Basically I replaced my front brake discs over the weekend. I re-used the pads as they've not long been changed & there is loads of chunky meat left on them.
I came to bleed my calipers & this is where my troubles start.
With the engine off, a few pumps of the pedal & the pedal goes from feeling spongey to quite hard. Great stuff. But with the engine running, the pedal goes fairly soft under foot & makes a kinda whooshing noise as I press & doesn't go hard. I got a mate to help me bleed them, pressing the pedal a few times, holding & I was on nipple crack duty. There seems to be no air coming through the tube, just regular good old fluid. What am I doing wrong?
Thanks in advance, M.
