punch wrote:Thanks for reply manifold and glow plugs not been touched had 4 new injectors 3 months ago hopefully just the seals on the manifold .
knobby1 wrote:punch wrote:Thanks for reply manifold and glow plugs not been touched had 4 new injectors 3 months ago hopefully just the seals on the manifold .
Ah...there's a clue....if the injectors were replaced....were the copper washers also replaced..?? If so, were the washer seats cleaned and/or refaced..?? If not you may have a wee bit of "Blow-by" which will blow a bit of oil through the breather system, into the turbo & intercooler... and thence into the manifold...worth checking the injector bolts/clamps for correct torque at least.
Do you have any oil weeping from the injector oil seals in the rocker cover..??
Users browsing this forum: camy1960, Google Adsense [Bot]
