knobby1 wrote:D4D wrote:If I remove the manifold will there be gaskets that need replacing before putting it back on? or can I just remove it, clean it and put it back on?
The manifold has 8 separate rubber/silicone packings/gaskets, they slip into grooves in the manifold, once you get the manifold off you'll see.
If the gaskets are still in good nick you can probably refit them...but they're fairly cheap to buy ....unless you go to Ford.
These are cheap Chinese ones but should be ok:....
http://www.ebay.com.au/itm/8-x-Inlet-Ma ... Sw03lY7DBy
Oh....and be sure to wear latex/rubber gloves when working on or cleaning the inlet manifold too....otherwise you'll be wearing black "spooge" gloves for days afterwards...
Latex gloves are for girls lol
Good dose of barrier cream does the job
