Comfortable driving at 30mph?
Postby Karst » Thu Apr 06, 2017 7:53 pm
Hi All,
Despite several years of driving a Mk6 and being very happy with it apart from the rust, I finally have to acknowledge that it has a gearbox not designed to be happy at 30mph.
30mph in 3rd gear along the flat is over-revving, and in 4th gear it struggles. It seems about 25mph is the highest comfortable speed in 3rd gear, and 4th gear seems designed for a minimum of about 38mph.
Does anyone know of any cure for this?
Karst.
Ford Transit Mk 7 Panel van, ex-posty's, 57 reg, 2007. Duratorq TDCI 2.2 (85PS)
Karst
Re: Comfortable driving at 30mph?
Postby knobby1 » Thu Apr 06, 2017 8:50 pm
She's not well....you'll need codes read. Is the glow plug light flashing etc...??
She should happily plod along at 60mph in 5th.
Postby Karst » Thu Apr 06, 2017 9:32 pm
I thought it must be a physical matter with the ratios of the gear cogs...??
It's been like this since I got it 4 years ago. The glow plug light never flashes.
Yes, 60mph in 5th is fine.
Karst
Postby knobby1 » Thu Apr 06, 2017 9:39 pm
Karst wrote:I thought it must be a physical matter with the ratios of the gear cogs...??
Ahh...I thought you meant it wouldn't go over 30mph....my bad. :oops:
There's nowt you can do about the internal gearbox ratios though....there are a few different final drive ratios available though.....FWD or RWD..??
Postby Karst » Thu Apr 06, 2017 10:03 pm
It's a front wheel drive.
Why did Ford make a gearbox that is not happy at 30mph???
Karst
Postby garnhamr » Thu Apr 06, 2017 10:33 pm
i hate driving at 30
garnhamr
Postby knobby1 » Fri Apr 07, 2017 12:48 am
Karst wrote:It's a front wheel drive.
TBH...you're possibly the first we've had that has this issue...There should be plenty of torque available at low-ish rpm.
There's only two diff ratios for the FWD Mk6, 4.23:1 and 4.54:1... they also have two different axle splines....26 splines up to the end of March 2003 and 36 splines after that.
Postby ake » Fri Apr 07, 2017 7:08 am
Based on the fact that it an early mk 6, I'll guess that it's a 75ps.
A remap would vastly improve the low down torque
Postby Karst » Fri Apr 07, 2017 7:59 am
Yeah, it's registered September 2000, X-reg.
So is the only thing I can do about this is get a remap?
I mean, I should at least try this first, right?
Karst
Postby Karst » Fri Apr 07, 2017 8:30 am
In my Google searching I have stumbled across RaceChip. I have taken the plunge and ordered the Ultimate model !
Karst
Postby Mike » Fri Apr 07, 2017 8:57 am
Karst wrote:In my Google searching I have stumbled across RaceChip. I have taken the plunge and ordered the Ultimate model !
I can only see a Racechip box for the 125ps MK6?
Mike
Wind up merchant!
Postby ake » Fri Apr 07, 2017 7:28 pm
Karst wrote:Yeah, it's registered September 2000, X-reg.
Well it's cheaper and easier than changing the gearbox!
Postby Karst » Fri Apr 07, 2017 8:47 pm
Yes, Thank you Mike, you are quite right about the RaceChip! That's no good then.
And Thank you Ake.
I found out it is a 75PS engine.
I also got it remapped today by someone who my local, long-standing, and very reliable mechanic uses. I drove about 6 miles afterwards, and barely noticed any difference at all.
Thank you knobby1.
It cost me £300 to get the remap today. I'll give it a week to be sure, but if this is all it does, nothing has really changed much :evil: :x :cry:
Karst
Postby Mike » Fri Apr 07, 2017 8:55 pm
Doh, you should have gone to Vantuner.
Mike
Wind up merchant!
Postby Karst » Fri Apr 07, 2017 9:20 pm
Googling Vantuner, I found vantuner.co.uk based in Uxbridge, not very, very far from me but not just round the corner. Have I found the right one? What makes him better than the fella I just used?
Karst
