Karst wrote:I'm just going to keep prodding somewhere and asking mechanics until I find the answer or simply reach multiple dead-ends.
I shall report back when there's something worth reporting.
Who the blazes designed a gearbox for a workhorse on the British roads that does not like 30mph? What is behind that?
Karst wrote:Hi again knobby,
I know why all the other transit drivers don't have the same drama.... How many have you seen who drive at 30mph?!
Karst wrote:Thinking about it, the final drive ratio is a secondary way to cure this problem. If it is made higher, then the uncomfortable speed will only be lowered to below 30mph somewhere. The real problem is still in the gearbox, the ratios are not crossing properly over from 3rd to 4th. I don't really experience problems like this in other gears, not to say they don't exist, but if they are there I don't really drive at the speeds where they appear. I could probably do with closer ratios and a sixth gear.
bambi mk 1 wrote:This will sort your problem http://www.motorparks.co.uk/upload/ford ... omatic.jpg
Karst wrote:Just the next time I think I have a bit of cash to spare I would try to find out about a different gearbox.
