Blue smoke on start up
Postby Retired John » Wed Apr 19, 2017 8:13 am
Finally got all the other s##t sorted now it blows shiploads of blue smoke when started up first thing after sitting overnight or longer , after it warms up or is 2-3km up the road no more smoke or if stopped and restarted through the day , still have not replaced the glow plugs ( slack ) so they are disconnected would this effect it ? other suggestions have been seepage past the valve stems when parked ? all suggestions welcome :?
Retired John
Location: Casino NSW Australia ......... 2002 125 T425 TDDI
Re: Blue smoke on start up
Postby knobby1 » Wed Apr 19, 2017 8:19 pm
Blue smoke is usually oil but could still be a glow plug issue as it's getting a little cooler now here in down-under land, yours is the 125ps TDDi isn't it..? I "think" the higher ps TDDi's like using glow plugs from cold, not so much the lower powered ones.
Is she using/burning a silly amount of oil..? When warmed up, does she blow a lot of smoke after idling for an extended period..? Any blue/white smoke on hard acceleration?
Might pay to get the glow plugs sorted at least.
Postby Retired John » Wed Apr 19, 2017 10:50 pm
Nobby it is not using oil thats the dilemma and yes the first burst of throttle when out on the road she blows shiploads then it is over , I got a set of glowplugs and seals from Mick at Hervery Bay so just need to get them installed :? It was just after all the drama with gaskets and starters where every time I touched or changed stuff it turned to shite I was reticent to muck with it as apart from the smoke she is running like a swiss watch with no leaks now :lol:
All my concerns re the power steer leak were for nil it was the rubber ring on the inlet pipe into the box a 20c part and 5 min job 8)
Retired John
Postby amlav » Thu Apr 20, 2017 10:06 am
I had similar issue with my previous van (Mazda) . Smocked like hell for a few minutes in the mornings untill had the valve stem seals replaced .
amlav
Postby Retired John » Sat Apr 22, 2017 12:10 am
Well I have decided to attempt to sort the seals chemically first so will give her a dose of thishttp://www.ebay.com.au/itm/LIQUID-INTEL ... 1414918532
It comes well recommended has anyone here used this ?
Retired John
Postby Retired John » Wed Jun 21, 2017 5:36 am
Well just to update the results for anyone having similar issues :wink:
The smoke started to diminish after 500-800 km and after a run to ACT 2400km and back it is gone completely not a sniff at start up fanbloodytastic 8)
Also found out she will start even at -5 without glowplugs but took some winding over and lots of black smoke after starting but no blue :wink: .
It was never a oil burn issue when running and just on startup after sitting overnight , the engine still shows as overfull the same as it did after adding 700ml of the additive 100ml/Litre so not using oil 8)
I felt sure there would be some oil use on the run home from Yass to Casino 1200km in 14hrs was a tough day and a big test as I was ringing her neck for every km and rarely dropped below 3000rpm even in the hills the only change was the gear it was in :evil: not fun but it was a must do situation even the fuel consumption was acceptable at 14L per 100km :)
Retired John
