Well just to update the results for anyone having similar issues
The smoke started to diminish after 500-800 km and after a run to ACT 2400km and back it is gone completely not a sniff at start up fanbloodytastic
Also found out she will start even at -5 without glowplugs but took some winding over and lots of black smoke after starting but no blue
It was never a oil burn issue when running and just on startup after sitting overnight , the engine still shows as overfull the same as it did after adding 700ml of the additive 100ml/Litre so not using oil
I felt sure there would be some oil use on the run home from Yass to Casino 1200km in 14hrs was a tough day and a big test as I was ringing her neck for every km and rarely dropped below 3000rpm even in the hills the only change was the gear it was in
not fun but it was a must do situation even the fuel consumption was acceptable at 14L per 100km
