Hi all,
Back after my adventures with clutch fitting
So, my van's been getting progressively worse at selecting 1st when setting off from a stop. Clutch down, and the gearstick just won't push in. No grinding of gears. I think I can even lift my foot off the clutch pedal whilst trying to push the gearstick in and it doesn't grind. However, if I put it in 2nd then go for 1st (without moving the clutch), it goes in OK.
Otherwise, gears can be selected OK, and I can select 1st OK whilst the van is moving.
Doesn't happen all the time, but I'd say >50% of the time it doesn't go in to 1st.
Is it the gearbox on its way out (synchros?), or (hopefully) something cheaper?
5-speed MT75 box, other van specs as below.
