MrFlibble wrote:Looking around, it looks like the plastic is likely to be ABS, so rather than superglue (cyanoacrylate), I'd be tempted to use a more specialised adhesive. Try a plumbers' merchant for "solvent weld" adhesive for ABS waste water pipes.
Jaffasoft wrote:What about 'Araldite' got a bit of that too?!
Jaffasoft wrote:Parked up out in the pouring rain like mad here tonight... won't be able know anymore what it's made of until can get under get it off. I like the idea of buying a couple of em. Well I was planning going away few days that may not be happening now.
Jaffasoft wrote:P.S. When we buy things form China sometimes.... it takes about 6 weeks to get around to Australia.
Jaffasoft wrote:MrFlibble wrote:Looking around, it looks like the plastic is likely to be ABS, so rather than superglue (cyanoacrylate), I'd be tempted to use a more specialised adhesive. Try a plumbers' merchant for "solvent weld" adhesive for ABS waste water pipes.
Thanks for researching and bringing that specific information forward.
I have some "solvent weld" , it's a blue coloured thick liquid paste that goes on PVC pipes when you join them for water proofing, because I have done a bit with it self plumbing a little. Will look into it a little!
rustytransit wrote:Mental! A new cap and piece of mind , or a 99p tube of superglue which is doomed to failure and a big £££££££££
MrFlibble wrote:I would agree, but if it's going to take weeks to arrive, maybe a properly glued one could work in the meantime.
