metal shavings in oil
Postby phdmarine » Fri Apr 21, 2017 12:22 pm
Hi, i have a 14 plate mk7 with 42k miles on the clock. Dipped the oil yesterday and metal particles were on the end of the dipstick.
Changed the oil and it was just full of them. was serviced 2k miles ago, none then. Any ideas? Typical 1 month out of warranty!
phdmarine
Re: metal shavings in oil
Postby loot » Sat Apr 22, 2017 9:46 am
Have you looked on etis for any recalls?
07 350 170ps
Ids map here
loot
Postby Punto443 » Sat Apr 22, 2017 10:41 am
Possibly oil pump?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby ake » Sat Apr 22, 2017 7:25 pm
Punto443 wrote:Possibly oil pump?
That's my first thoughts
Postby phdmarine » Mon Apr 24, 2017 3:43 pm
checked etis for recalls, none showing.
van was recalled in first year for the oil pump, was done at the time.
my local garage does suspect the oil pump, they said to contact arnold clark to see if they would help as we have had quite a few vans from them, just waiting for them to get back to me.
forgot to say, van was recently remapped and dpf removed, they claim that will have had no ill-effect, just getting an extra 150 miles per tank.
phdmarine
Postby karl » Mon Apr 24, 2017 7:50 pm
If you have metal in ya oil stop driving it
It will cost you more money to repair it
Dont except any dealer to sort it out for you under warranty. They will tell you to do one :(
Does oil light go out have you had the oil pressure tested
I would be checking the turbo on this year as well
karl
Tranny Lover!!!
Postby pp5858 » Tue Apr 25, 2017 1:12 pm
One practical hint (not sure if it is applicaple in UK).
In Finland warranty eg. 1y starting eg. 1:st Jan will last 1y. But you have reasonable time to report the issue and that in Finland is 2 months. So even after 1y waranty has expired as long as you say during 2:nd month e.g. February that the issue started at december but you have not got time to report it earlier, it is still covered by warranty. Have managed to report one hard drive like such abt. 58days after warranty expired. :)
pp5858
Postby loot » Tue Apr 25, 2017 1:29 pm
In the uk we have lifetime warranty but it can only be reported to the warranty inspector general otherwise it won't be honoured.
Warranty inspector general :arrow:
https://youtu.be/s6jYoagXmZE
07 350 170ps
Ids map here
loot
