ake wrote:They are not all the same, but as said, it will work
scas wrote:ake wrote:They are not all the same, but as said, it will work
im guessing if it is different the power wont be effected?
Jim Archer wrote:What makes you think it's the turbo?
Jim
trannyfreak wrote:I got a t280 125ps mk6 transit with boost problem so I'm just going to change the turbo so like said before can I take a turbo off any mk6 transit and will it work as it should also do I need to take out the engine to change the turbo many thxnks
ake wrote:trannyfreak wrote:I got a t280 125ps mk6 transit with boost problem so I'm just going to change the turbo so like said before can I take a turbo off any mk6 transit and will it work as it should also do I need to take out the engine to change the turbo many thxnks
No because yours is probably fwd, and so will be a tdci, so you need a turbo from the engine.
Users browsing this forum: Google Adsense [Bot], reevco62
