I have tried to make keyless entry system model lb402 work as my original fobs fail. I wired the red to battery. The black and yellow to door screw. Where do i wire the white and white black striped to?
So the first question here is do forrd transits ise electri. Or pneumatic central locking. Second if electric then positve wiring or negative triggerwiring. Tnird where to attach wires to. Door or where under dashboard? This is a cheap way to get an electric lock going with no original ford keyless key but I doubt ford will give their specifica.
I actually wonder what colour wire is plus and what one opens the rear door when you press the rear door button on the fob. Mine does not open. Rest works fine.
