Try the forum search tool buddy....the same topic has been covered 1001 times.
I'll maintain my stance that it depends on what you are using the van for & how much weight you carry....under geared is an arse - over geared is a pigs arse.
You need the engine torque to pull the higher gearing & a 6-speed box works much better with a 3.73 due to first gear being slightly lower & a better spread across the remaining gears.
Try another van with a 3.73 before changing yours would be the way to go.
