wronghole wrote:Know body no then ?. I've heard a resonator ? or flame trap?
wronghole wrote:So really all it does is connect two pipes together and leak oil
wronghole wrote:Its been like that for 3plus years and also never had to top up oil between services as any oil loss is minimal if any. . Think I might get the spanners out and give it a good clean . If it ain't broke don't fix it comes to mind
knobby1 wrote:wronghole wrote:Its been like that for 3plus years and also never had to top up oil between services as any oil loss is minimal if any. . Think I might get the spanners out and give it a good clean . If it ain't broke don't fix it comes to mind
There's always a bit of oil mist being pumped around the air inlet side of the engine, the crankcase breather essentially goes straight into the turbo inlet and then this goes through the turbo and back into the engine to be burnt again...a never ending cycle. Some people fit a breather separator which may help with the amount of oil mist etc...helps keep the intercooler, boost hoses and inlet manifold free of spooge too...doesn't stop it altogether but every little bit helps.
wronghole wrote:knobby1 wrote:wronghole wrote:Its been like that for 3plus years and also never had to top up oil between services as any oil loss is minimal if any. . Think I might get the spanners out and give it a good clean . If it ain't broke don't fix it comes to mind
Cheers mate
