Altransit wrote:I had to do this at the weekend, on a TDCi
You need to give it a sniff of easy start or similar, turn engine over for 10 seconds only. Rest it for a minute or so. Repeat this as many times as you need until it tries to start, 2 or 3 times should be enough.
Repeat a couple more times and it should run for longer and longer, until you can finally rev it.
That should be it, unless you have a fuel supply problem or an air leak
trannyfreak wrote:OK cheers I'll get another housing again today and have another bash at it
