Ford transit Mk6 2001 not always starting
Postby VanMarco » Tue Apr 25, 2017 4:00 am
Hi people,
I own a Mk6 Ford Transit 2.4 TD51 plate, 2001. Basically what's happening is that it does not start... always.
I turn the key on, wait for the glow plugs light to turn off and try to crank it, nothing happens. Just a single sound from the engine compartment
like a click but not quite. Sometimes before I try to crank, I could hear some kind of whirring noise. I switch everything off and repeat, several times, and then it fires.
What I have excluded so far. Relay 1 and 13 ignition and starter. Switch on the ingition and key block. Looked under for any signs of corrosion
on the starter motor contacts. Battery is tested good. I don't know what to think other that there could be a problem with the solenoid on the starter, or the ECU has gone crazy? Any input would be appreciated
Thanks!
VanMarco
Re: Ford transit Mk6 2001 not always starting
Postby ake » Tue Apr 25, 2017 7:11 am
My money is on starter
Postby ned » Tue Apr 25, 2017 8:28 am
How have you ruled out the starter, I'm with Ake the starter is dying. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby VanMarco » Tue Apr 25, 2017 1:00 pm
well I did not rule out the starter, I just checked if the contacts were rusty or anything but I didn't take it out and bench tested. To remove this part, it seems there's a brake system pump mounted over it, will I be able to take it out without taking also this pump out? Thanks for the help!!
VanMarco
Postby ake » Tue Apr 25, 2017 5:51 pm
VanMarco wrote:well I did not rule out the starter, I just checked if the contacts were rusty or anything but I didn't take it out and bench tested. To remove this part, it seems there's a brake system pump mounted over it, will I be able to take it out without taking also this pump out? Thanks for the help!!
Starter comes out with removing anything else
Postby VanMarco » Wed Apr 26, 2017 6:32 pm
hi, thanks, I've seen how to take it out. As i was there and I had a helper I measured the voltage on the starter itself while cranking I got 8.39V I don't know maybe I was wrong about the battery, but it seems odd as sometimes it started no problem
thanks
VanMarco
Postby MB15 » Wed Apr 26, 2017 8:27 pm
Sounds like the starter is sticking if you have plenty voltage , Remove & bench test it ,
If it does it again while on the van - give it a whack
2.2 - FWD - 2009 - SWB
MB15
Postby VanMarco » Thu Apr 27, 2017 7:06 pm
Ok today i took the starter out big pain in the ass, it seems to be faulty. I bench tested it, and not only i get a strange gravelly sound, also it does not always engage when the trigger terminal is triggered, It also have lost the dust cap on the side. Will update once refitted a new one
thanks a lot!
VanMarco
Postby VanMarco » Wed May 03, 2017 4:04 pm
starter replaced, still no go. I have also changed the battery to be 100% sure, I have excluded so far, ignition switch, relays, starter and battery and all I hear when I turn the key is the same "clunk" and no start. The ! signal switch on as I turn the key, but thats it
Im out of ideas
anyone?
thanks
VanMarco
Postby alexandrey » Wed May 03, 2017 4:11 pm
Mine did the same new starter and new battery, not always starting just clicks 1-2 times and then starts, after i cleaned battery terminals starts every time but now when turning the key and starts someting clicks under the driver seat (where the battery is) what you guys think that can mean??
2001 mk6 Ford Transit T260 2.0
alexandrey
Postby VanMarco » Sat May 20, 2017 1:16 pm
Ok i found what was wrong, LOL, i forgot to reconnect the big cable to the starter. Starter solenoid was faulty, so a new starter fixed it.
Thanks!
VanMarco
Users browsing this forum: Google Adsense [Bot], richardstubbs
